Thread: how to tell if gauge is broke or pump about to blow?
    Chattanooga, TN
    Default how to tell if gauge is broke or pump about to blow?
    I just uncovered the pool today and adding water (drained it below the return over the winter).
    When it had enough water I turned on the pump and everything sounds normal. But the gauge on the sand filter is maxing out at 100psi. I backwashed for a min but it wasn't dirty and psi didn't drop.
    Is it just a bad gauge you think? Anyway to tell for sure other than just buying another gauge?
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump, Sand Dollar sand filter, Polaris 65 vacuum
    Default Re: how to tell if gauge is broke or pump about to blow?
    Does the gauge drop to 0 when the pump is off?
    I'd suspect the gauge first.
    However, how's the return action?
    Lucky you to have the pool open already - Hope you have a great season!
    If you left the gauge outside at all when the air temps were below freezing, then it's a goner for sure....they are fairly inexpensive and easy to replace. Try replacing it and see what you get.
    Honesdale PA
    If it was really reading 100 psi I wouldn't want to be near the sand filter. I think they're typically rated for 50 psi max. Besides, regular pool pumps can't hit that high pressure. Gauge is croaked.
  1. Hayward Skimmer Flaper Broke
    By gfritz1 in forum In-Ground Pool Construction and Repair
    Last Post: 06-18-2010, 10:57 AM
  2. Using Pool Pump to Blow Out Lines?
    By NullQwerty in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-07-2007, 04:52 PM
  3. Pump broke so SWG cant work- slime-what to do?
    By melifair in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-29-2007, 04:49 PM
  4. i broke my hayward ec-65 de filter
    By fog80 in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 01:30 AM
  5. Going broke with pop ups!
    By thovan in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-13-2006, 10:44 PM
