Results 1 to 10 of 27
Thread: I'm Ready For Nice Weather!
    Lehigh Valley, PA
    Default Re: I'm Ready For Nice Weather!
    Thanks for the 'welcome back', Janet. Once I started reading through some of the older posts here I realized how much I had liked the warmth and fellowship here.
    Has anyone heard from Lisa?
    Anna
    I'm here! Still on one of my chemo drugs taken orally every day and also recovering from my surgery. Kinda slow going though which according to my surgeon is pretty typical for someone who previously had radiation. She said surgeons don't really like to operate on someone who has already had radiation because you don't know how well they are going to heal. She is also referring me for physical therapy. After having lymph node surgery twice now, I am having some range of motion issues. And, as if I need something else, I am having pain in the calf of one of my legs. Had an ultrasound looking for a blood clot a week ago but nothing showed. They may want to repeat it as sometimes it isn't found on the first try. The other thing it may be (and what I actually think it most likely is) is a bulging disc in my spine causing some sciatic nerve pain. As long as it doesn't rupture like I had happen about 9 years ago. It was EXTREMELY painful so hoping that doesn't happen. Not sure what I hope it is. Blood clot or disc problem? Neither one is a very good choice. At any rate, I'm doing ok and ready for spring! Thanks, Anna, for asking!
    Lisa
    Hurting, in pain, AND this lousy weather? Ouch! We had a few gorgeous lovely days after lots of storms, then more storming and lousy weather. We lost three trees just over a week ago.
    Lehigh Valley, PA
    It sure was good to hear from you, Lisa! Though I am sorry to read about the aches and pains and all that in addition to what you're already going through. I have sciatica now and then as a result of a slipped disc and OUCH! You have my sympathies!
    No robins here yet but the forsythia have that distinct yellowish tinge they get just a couple of days before the blossoms open. And the lilac buds are about to burst.
    We opened out pool over the weekend. That's just a manner of speaking because we don't cover it over winter. We connected the plumbing and are in the process of topping it off it from the well which will take several days. The tests I did this afternoon are all within acceptable ranges, FC is way low, of course, so I think I'll go dump in a bottle of bleach and stir it up with the leaf net. Gives me something to do on a sunny afternoon and keeps me off the streets, as they say.
    Anna
    Honesdale PA
    The stupid robin birds arrived here a couple weeks ago and unlike prior years, the day after was nice with no ice. Got all my equipment hooked up yesterday and the only thing I'm dealing with is a tiny leak at the pump outlet fitting. We're supposed to get a little snow in the next couple days though. Won't last, temps are too high but at night it will dip into the 20's. Probably will take the plow off the tractor and put the mower deck on in the next couple days. I sure am enjoying warm days for a change. Yes, 50's seem warm.
    Lehigh Valley, PA
    Sigh.
    The weather is messing with my head and I am not happy! This business of opening in March is great and all but then the weather people tell me it's gonna drop to 22 F tonight and all I can think of is the water that's now in my pump and filter.
    We haven't done a leak check yet, haven't run the pump yet, I'm contemplating plugging in a heating pad to cover the pump. Pardon me, but this sucks!
    Is a night's worth of 22 F enough to crack the PVC pipes?
    Honesdale PA
    Can you just run the pump? Water in pipes has to freeze solid before they break. The temp probably won't be low enough and long enough to do damage. The mass of water in the pump and filter won't even come close to freezing in one night. If your gauge is on the filter you'll probably lose that. It's a low thermal mass and water in the tube will freeze and screw up the zero and calibration. Cheap to replace or if it's good now just unscrew it and take it inside. If you have a multiport valve on top of the filter put the handle in an intermediate position to let water drain out of the valve assembly. Being north of you all I plan to do tonight is wake up around 3 and run the pump for a couple minutes and go back to sleep. Being lazy I'll just put the laptop by the bed and won't even have to get out from under the covers to do this.
  1. Loss of water in cold weather
    By ralph in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-20-2012, 12:45 PM
  2. Cold weather!!!
    By salinda in forum Pool Equipment & Operations
    Last Post: 03-13-2007, 12:36 AM
  3. Cold Weather
    By DONNIE in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 11-06-2006, 07:22 PM
  4. SWG and cold weather
    By CanuckPool in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 10-09-2006, 02:28 PM
  5. SWG or Very nice BBQ Pit
    By Pool_Mike in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-04-2006, 01:50 AM
