Results 1 to 10 of 20
Thread: changing pool water
    Scottsdale, Arizona
    Default Re: changing pool water
    just for fun, last week I took a water sample to 3 different pool stores... and got 3 different results. whoda thunk it
    You should really get yourself a proper test kit. The best to get would be the Taylor K-2006. Most importantly, you need to get chlorine into your pool. Unfortunately, if your CYA level is now too high, you'll need a lot, but until you get your good test kit just add a bunch of chlorine to have at least 5 ppm FC or more which will max out your inexpensive test kit. Use The Pool Calculator to calculate dosages and check your water as the chlorine may get used up during the day or fighting algae.
    Chem geek's link isn't working--he meant http://www.amatoind.com/taylor-k2006-test-p-555.html
    Quote Originally Posted by Phillbo View Post
    Sure glad no one around here believes in sarcasm!...........
  1. What is involved in changing depth of a pool?
    By ilene in forum In-Ground Pool Construction and Repair
    Last Post: 08-13-2012, 01:16 PM
  2. Hunger for chlorine after changing pool water ...
    By paulshikleejr in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-22-2011, 08:35 AM
  3. changing pool pump cord
    By pcasey61 in forum Pool Equipment & Operations
    Last Post: 03-20-2009, 06:08 PM
  4. Changing configuration of IG pool....
    By heatherc in forum In-Ground Pool Construction and Repair
    Last Post: 08-01-2007, 02:24 PM
