Thread: Do I need "Liner Lock" for Beader Liner
    Aranon is offline Registered+ Thread Analyst Aranon 0
    Default Do I need "Liner Lock" for Beader Liner
    I have found "Liner Lock" that says you install it in the beaded track after you install the liner to lock in the liner and keeping the bead from coming out.
    I have never heard anyone mentioning this and no one talks about it. I have heard on some post of the beaded type liner coming out of the bead track.
    Do I need this product. I found it at a couple of places with this one being the cheapest:
    http://www.cheappoolproducts.com/Lin...7~product.html
    So can anyone tell me if I need this. Is the liner coming out a problem. Please tell. Thanks
    Aranon
    Default Re: Do I need "Liner Lock" for Beader Liner
    Hi, usually this is not a problem. It does happen on occasion however. I would hold off buying it until you really need it. It could be soon, in a year or two or probably never.
    Just my thoughts, Dennis
    Thanks Dennis, you the man!
    Oh, btw did you find any pics of oval pool going up?
    Aranon
  1. fading "tie-dye" liner
    By alisonquilts in forum In-Ground Pool Construction and Repair
    Last Post: 06-30-2012, 09:29 PM
  2. how to reattach vinyl liner in spot where it's slipped out of the "channel"
    By tenax in forum In-Ground Pool Construction and Repair
    Last Post: 08-06-2011, 06:44 PM
  3. Stubborn "bathtub ring" around vinyl liner
    By Scetnk in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-23-2011, 11:46 AM
  4. how should I "cut in" skimmer and return holes in the liner?
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 07-06-2007, 12:53 AM
  5. Which liner for the "lagoon" look?
    By induce in forum In-Ground Pool Construction and Repair
    Last Post: 09-13-2006, 08:25 PM
