Thanks Poconos. Bear with me here as I would like to ask a couple more questions.
1) As I was using the compressor (attached to gizzmo thru skimmer) and was working around the returns, air was blowing out thru each one as I capped them. Not constant air, but almost. I was sure to cap it as a surge of air was coming out. Can I be sure that the returns are good for a MN winter?
2) I read just about every single old post on blowing the lines. I know I can go suck out any remaining water in the deep end skimmer and use the antifreeze, so I'm not worried about that. Am I correct in my thinking?
3) I fiddled with the main drain valve quite a bit. I closed it after it bubbled, but since it wasn't bubbling at the exact minute I closed the valve, I was concerned. So reopened it and continued to try to get it to bubble again. It never did. I assume water "fell back" into the main drain and that it still needs to be blown out. Is this correct?
4) After I was all finished last night and reading all the old posts, I saw that Waste likes to drain the equipment before blowing the lines to avoid that water from recirculating thru the system. Does that happen even when the multiport is set to "recirculate?" If so, could that explain all the gurgling I heard when I should have been finished?
5) Is there a way to connect the air compressor somewhere other than the skimmer that would give me a better "surge" to blow the main drain? Or is the skimmer the best place? Maybe I should try the technique with the bike pump I read about last night? I've got a sprinkler guy coming today. Maybe I can talk HIM into connecting to my skimmer!
thanks. I can't promise I won't have more questions, but with 3" of snow now on the ground, a high of 35, lows in the mid 20's, and the pool people not coming till Friday, I hope I did the right thing. If I can somehow get comfortable that I've done a 100% good job, I will call the pool people and cancel. Please, please help me to do so!
Jennie
