Thread: Should I adjust anything ?
    Michigan
    Default Should I adjust anything ?
    PS 233 Results
    Pool is clear
    FC= 6.5
    CC=0
    PH=7.2
    ALK=140
    CYA=60
    Temp=58
    In Ground Liner - About 32K Gallons with electric cover
    Default Re: Should I adjust anything ?
    Only the temperature! 58 is too cold! Everything else looks great. Just keep an eye on the ph and don't let it drop any lower. Other than that, it is all right on track. I would suggest not using any form of stabilized chlorine, however. CYA at 60 is OK, but you don't really want it to go any higher. Just use bleach. Enjoy!
    Watermom pretty much covered it, the only ? is; how do you chlorinate your pool? ( If you're using 'other than bleach' there are some things to watch out for, in the future)
    Just a 'heads up' - Waste
    Michigan
    I am going to try doing only the bleach this year and see how it goes. Still have a few more questions though.
    1. My pump is on a timer and I normally have it shut off at night. If I add bleach at night how much time should the pump be running after I add bleach before it shuts off. ? (1 Hour??)
    2. Do I need to watch my CC level or just the FC ? My CC is at 0.
    I usually try and run my pump for a couple of hours after I add bleach. As far as testing chlorine goes, you should keep an eye on both FC and CC, but probably checking CC weekly is sufficient unless you have had a lot of swimmers, rain, debris, etc. After awhile you pretty much get to know your pool and how it behaves. Actually, I am very consistent with maintaining proper water chemistry and I seldom have any CC reading at all. Hopefully that will be true for you as well.
    Michigan
    Is it best to have no CC reading at all ? I have a 5.5 FC and 0 CC reading at this time and was concerned. Why is 0 CC good ?
    All this halp is great !
    Yes- you want your cc reading to be 0. Combined chlorine is the chlorine that has been 'used up' getting rid of all the goo in your water and is no longer available to sanitize your pool. If you have a cc reading of 0, it means you don't have any organic stuff trying to take over your pool.
  1. How to adjust CYA down
    By l8nite4me in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-13-2007, 03:27 PM
  2. How to Adjust pH and TA
    By iwannapool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-15-2007, 04:22 PM
  3. What should I adjust ?
    By aswetich in forum DPD-FAS based testing
    Last Post: 07-27-2006, 06:33 PM
  4. Adjust TA first, right?
    By jnorris in forum Dealing with Alkalinity and Calcium
    Last Post: 06-30-2006, 10:07 AM
  5. Which one should I adjust first
    By Sunny32504 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-23-2006, 12:32 PM
