Actually while you are fighting an algae bloom, you don't need to worry about the cya. Clean up the pool and then add it later. For now, try and test as many times a day as you can and each time add enough bleach to get back up to shock level. The more often you do, the faster your pool will clear. Also, run the pump 24/7 while you are trying to clean it up. Keep us posted how it is going.
