Thread: blowing out lines with DE Filter?
    Default blowing out lines with DE Filter?
    hello, i used to do this through the pressure gauge hole on my old sand filter. now i have a De filter and was wondering how to blow out the lines with this type of filter? thanks Randy
    Cool Re: blowing out lines with DE Filter?
    If you have a multiport with a 'recirc' position, you can use the same adapter on one of the pump drain plugs
  1. Need help w/ blowing out lines IG pool
    By FPICOL in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-24-2011, 02:50 PM
  2. blowing out lines
    By pq1747 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-08-2010, 11:05 PM
  3. Help! with blowing out the lines using the pump drain plug!
    By Amir in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-06-2007, 05:16 PM
  4. Blowing out lines
    By jv4nu in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-05-2007, 03:04 PM
  5. Blowing out lines - Air Compressor
    By haeffnkr in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-07-2006, 11:28 AM
