Thread: Is skimmer weir removable?
    North Florida
    Default Is skimmer weir removable?
    Ok, me again with yet another issue on my new-to-me pool.
    The skimmer weir doesn't have full range of motion. It will lie flat (parallel with the top of the skimmer basket) and will float up maybe about a third of the way it's supposed to. Then it seems to catch on both sides of the skimmer so won't go any further.
    Pool seems to be only 3-4 years old, so I don't know why it has this problem. There don't seem to be any cracks or leaks in the skimmer area that I can see.
    The solution would seem to be to grind off a bit on each side of the weir so it can flap the way it's supposed to. But I don't see a way to remove the door - if that's even possible. If not, does anyone know of a way to grind away a bit of the sides of the weir? It's too tight a space to utilize any tools that I can think of - will some kind of wet sandpaper work?
    This weir is basically a flat piece of plastic - no styrofoam.
    Thanks for any tips you've got!
    Sandy
    Default Re: Is skimmer weir removable?
    They usually are. They usually have a spring-loaded pivot kinda like a toilet-paper holder--but usually with two handles or pins you squeeze together. Standard ones like Hayward always have them and you remove the weir for the winter.
    North Florida
    Thanks Carl...I THINK I see something that's kinda like what you describe. I'll fiddle with it the next time I'm in the pool.
    Sandy
  1. Cannot figure out how to install a Hayward Skimmer Weir
    By Casey in forum In-Ground Pool Construction and Repair
    Last Post: 07-20-2011, 10:17 PM
  2. Air in system won't let pump hold pressure (Skimmer weir stuck)
    By cmcq in forum Pool Equipment & Operations
    Last Post: 07-05-2008, 12:53 PM
  3. Tab on skimmer weir broken
    By trauh in forum In-Ground Pool Construction and Repair
    Last Post: 08-10-2007, 08:12 PM
  4. Skimmer replacement "circular weir" questions.
    By Socal_biker in forum In-Ground Pool Construction and Repair
    Last Post: 10-10-2006, 04:55 PM
  5. Changing the weir gate in a Jacuzzi PMT skimmer
    By davegs in forum In-Ground Pool Construction and Repair
    Last Post: 06-11-2006, 11:46 PM
