I have a Pentair Fac Fab Star ST50 DE filter with a 1HP Dynamo pump. My filter has not been holding the DE and thus it ends up in the bottom of the pool. Took it apart and noticed a TINNNNYYY tear in the bottom corner of one of the grids. Everything I read says that will do it (hard to believe). Also, the bottom manifold that the grids sit in had 2 of the prong-things broken off (we bought this whole system used). So I ordered a new grid, new bottom manifold and new screws off poolcenter.com. Hubby replaced everything and we started it back up (by this time, pool was green). Alas ~ SAME THING HAPPENING. We put the DE in slowly through the skimmer (4lbs. for 10,000 gallons as recommended). The next day we took filter apart and again, there was NO DE on the grids. Only the top 2" or so of each grid was covered in green gunk. The rest of the DE sludge was sitting in the bottom of the filter (and some on the bottom of the pool). Does anyone have this filter? Does anyone have ANY suggestions? We think we lost the check valve, but not sure if this is a problem or not. The purpose of this valve says it is to prevent DE from going back into the pump (not the pool).
Also to note: flow coming into the skimmer is not strong. Filter pressure starts at 10-12 and never changes (up OR down).
Any ideas???????![]()
