Thread: SWG and gas heater
    Ontario, Canada
    Default SWG and gas heater
    I am in the market for a gas heater, since I have a salt water generator are there any issues I should be aware about.
    Will the salt lead to corrosion in the heat exchanger, is my only option to buy a heater with a stainless steel core at three times the price, or can I get away with just a regular gas heater?
    I.G. Vinyl Pool 12' by 24' approx 10,000 gal, Hayward Sand Filter, 3/4 HP Hayward Super Pump, Hayward Aqua Rite Salt Generator, T-15 Cell.
    Davenj is offline Lifetime Member Thread Analyst Davenj 0
    Jersey Shore
    Default Re: SWG and gas heater
    I have a Hayward gas heater with no issues. If you keep your water balanced it won't be a problem.
    I agree with Dave. Keep your water balanced and keep a watch on your PH and total alkalinity especially and you should be fine with a copper heat exchanger. I would also recommend having a check valve installed. What that does is when the pump is shut off, no water can back up into the heater.
    Inground 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWG
  1. Spa Heater Help
    By Dstrot in forum Pool Equipment & Operations
    Last Post: 09-03-2012, 12:51 PM
  2. SWG before heater?
    By NomenNescio in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-08-2007, 01:06 AM
  3. Hi-E2 Heater ?
    By fjava in forum In-Ground Pool Construction and Repair
    Last Post: 07-19-2006, 05:52 PM
  4. Heater
    By hancop in forum In-Ground Pool Construction and Repair
    Last Post: 07-19-2006, 02:15 PM
  5. Can't run heater below 40f???
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-17-2006, 03:51 PM
