Results 1 to 3 of 3
Thread: Salt from Lowes
    Default Salt from Lowes
    Has anyone purchased salt from Lowes? If so, what did you buy? I am converting over to salt and my local pool store is very expensive.
    KPROMERO is offline Registered+ Thread Analyst KPROMERO 0
    Broussard, Louisiana
    Default Re: Salt from Lowes
    Solar salt, but make sure it does not have iron out and stuff in it,
    waterbear's Avatar
    St. Augustine, Fl
    Lowes in my area carries the Morton pool salt but they are more expensive than 2 grocery chains in my area that also carry it (Publix and Winn Dixie). Any plain water softener salt (pellet or solar) that is at least 99.5% pure and has no additives for removing iron or cleaning your water softener will work just fine. Pellets are slower to dissolve but with a bit of brushing it doesn't take that long.
  1. Salt water system faulting high salt.
    By Skelly607 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2013, 10:43 AM
  2. Aqua Rite low salt reading when salt has been tested high
    By DirtRider67 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-19-2011, 05:58 PM
  3. Salt Level Keeps High without Addition of Any Salt
    By TooSalty in forum The China Shop
    Last Post: 08-13-2011, 01:56 PM
  4. Can I use sand from Lowes
    By wendylolex in forum In-Ground Pool Construction and Repair
    Last Post: 05-04-2006, 05:15 PM
