We need you to post your current water testing results taken with a drops-based kit and not test strips. We need FC, CC, TC (or at least two of the three of those), PH, alk, cya. Then somebody here can better advise you.
But, to answer you quesion, yes, you are gonna need lots of chlorine. The key to killing algae is a sustained high chlorine level. Also run the pump 24/7 while you are trying to clear the pool. Repost with your numbers.
