Results 1 to 5 of 5
Thread: Loud Pump
    Default Loud Pump
    I have a PacFab Challenger 1hp High Flow pump that is making a loud whining noise. It is also leaking water underneath, where the pump motor is bolted to the impeller.
    the motor indicates it is a 1.65SF Centurion Challenger
    I believe this is the original motor on the pool, which was installed in 1994... could it be the bearings? is it best to fix or replace the motor or the entire hosing (motor and impeller section)?
    Thanks.
    Default Re: Loud Pump
    Sounds like the shaft seal has 'gone south' on you, if you replace that the motor should stop dripping However, the noise may or may not diminish, but at least you'll have solved the problem, and can then decide if you want a new motor
    Well, I took the item apart (for the most part)... it has a piece of plastic tubing about 2" long stuck in the impeller, along with some of those air soft bb's.
    How do I remove the impeller from the motor/shaft? I removed the reverse threaded screw without any problems, but the impeller, back of the housing (where the motor bolts too) won't come off.
    Do I just need to gradually pry it off? Is there a seal behind this where it may be leaking?
    Thanks.
    Here is the impeller side, with the screw removed, but the impeller won't come off. Does this impeller have to unscrew from the motor shaft as well? if so, how do I keep the motor shaft from spinning?
    markphin is offline Registered+ Thread Analyst markphin 1 star
    In your pic, pop that littler round nut off the back of the motor. This will give you access to the motor shaft. It should be flat at that point, so you can hold witha pir of chennel locks and then spin off the impeller.
  1. Loud Pump Noise?
    By Islander2C in forum Above-Ground Pool Construction & Repair
    Last Post: 06-15-2007, 07:39 AM
  2. Haywood Pump Loud
    By jojosail in forum Pool Equipment & Operations
    Last Post: 06-25-2006, 11:00 AM
  3. Abused pump - Now it's loud.
    By darrin in forum Pool Equipment & Operations
    Last Post: 06-20-2006, 09:39 AM
  4. HELP -- LOUD Pump
    By wrinkleigh in forum Pool Equipment & Operations
    Last Post: 05-25-2006, 01:46 PM
  5. pump very loud
    By sunofthebeach in forum Pool Equipment & Operations
    Last Post: 05-09-2006, 12:54 PM
