Results 1 to 3 of 3
Thread: Need help fast
    Sumo1 is offline Registered+ Weir Watcher Sumo1 0
    Default Need help fast
    Our church pool chemistry is usually maintained by the lifeguards but they're told to call us oldtimers if they see a problem. Lifeguard just called to say that he's been adding soda ash daily to keep pH up above 7.4 but that alkalinity has dropped to almost nothing. Advice??
    Hal
    20x40 IG gunite free form, approx. 27K gal, 60sq DE filter, Jandy Stealth 2hp 2speed pump, Polaris 380, SWCG
    Cool Re: Need help fast
    Hi Hal
    Without full test numbers all I can say is lots of baking soda! We can't be more specific without test #s and aprox. gallonage,
    I doubt it is a major problem, you just need to 'tweek' the chem levels
    Luv & Luk
    - Ted
    Default Re: Need help fast
    Thanks, Ted. It's great to be back in the Forum. The biggest challenge today is where to source the baking soda. I doubt we'll be able to do anything today but the kids tell me there's not too much traffic on Saturday evening. I'm working on other sources for 50# bags but probably won't have it before Monday. Pool's closed on Sunday, even when it's 98 outside. Pool's about 175K gallons, CYA's about 95, CL at least 8, pH 7.4( I got these over the phone from the lifeguard.) Bioguard 1200 test kit. He said the alk test sample goes from green to clear after 3 or 4 drops. He's added 50# soda ash in 1 week. Last time I tested the CH it was 200-250. Thanks for your help.
    Hal
  1. Can cya go down that fast?
    By DanS in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 11-14-2007, 09:50 PM
  2. Need help fast
    By Sumo1 in forum Dealing with Algae & Slime
    Last Post: 05-18-2007, 10:02 PM
  3. Fast Chlorine Dissipation
    By rqbanerjee in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-02-2006, 11:48 AM
  4. losing salt too fast
    By szcakes in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-24-2006, 11:49 AM
  5. Help !! Need assistance Fast !
    By TexasGirl831 in forum In-Ground Pool Construction and Repair
    Last Post: 04-29-2006, 01:20 AM
