Thread: Vinyl Chlorine pool - brownorange staining
    Default Vinyl Chlorine pool - brownorange staining
    This is a 10 year old vinyl IG pool that I have been maintaining using bleach borax for 7 years. This year for the first time on opening (NJ) , after I got it clear etc. all of my underwater fittings have turned brownorange, and there is the same staining on the floor of the pool where the floor outlets emit also.
    It will not brush off.
    I had a friend who had a fiberglass pool who had this problem all over and ascorbic acid rubbed on it took care of it. As soon as I am motivated I will try that to get rid of the stains, but does anyone have any idea what this is?
    Default Re: Vinyl Chlorine pool - brownorange staining
    Probably iron oxide.
    Get some vitamin C tablets at the store, put about 10 in a old sock and wipe your outlets with it. It works like magic, then get your iron levels corrected
    Jul 2006
    any update on this
  1. I can't maintain chlorine in my IG vinyl pool
    By Nysitemgr in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-13-2013, 10:42 PM
  2. use of liquid chlorine in AG vinyl lined pool
    By Darkside in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-10-2012, 07:36 PM
  3. Started the vinyl liner de-staining process... Some questions
    By JWB in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-03-2009, 01:47 PM
  4. Max chlorine in vinyl pool?
    By fade2_blk in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-16-2006, 10:04 AM
