Thanks for the replys,not sure I understand the reply about areation.My concern for the water chemistry stems from the problems from last year before the new liner.At what point will the low PH and or alkalinity cause metal to disolve?This problem may belong on a different thread but it pertains to chemistry of the water.
I had a staining problem that was caused by copper which was 1.0.It was thought it was coming from the heat exchanger. I installed bypass valves on the heater and planned only to use it at start up.Used it this year for two days to warm the water and put it back on bypass. Checked the water in the pool for copper and found a trace ,less than0.1 .This was not there prior to running the heater. After I bypassed the heater I thought about getting a sample of the water and drained it. The sample showed a 1.0 concentration of copper from the exchanger.Can my water be that corrosive or can the age of the heater be at fault? (10 years ,only used to start up and early fall).
