Thread: Can Sched 40 PVC be safely painted?
    Greater Hartford area, CT
    Default Can Sched 40 PVC be safely painted?
    Last year I hard plumbed my 24' AGP with white Sched 40 PVC. The filter and plumbing all get direct sunlight throughout the day. As a really, REALLY low tech way of solar heating, can I paint the PVC black and not affect its structural integrity? Can I do the same with outside of the filter tank (it's a Hayward Xtreme cartridge)?
    Thanks in advance.
    Default Re: Can Sched 40 PVC be safely painted?
    Sched 40 doesn't perform well when subjected to heat. However, you should be able to paint it with a latex-based paint, but I would strongly recommend against using anything but a low pressure flow through it unless you are relentless about always running it in sunlight so the water inside cools it.
    Remember, a slow flow that produces hot water won't heat your pool as much as a heavy flow that produces water just a few degrees warmer than your pool.
  1. Using Muriatic Acid to Safely Lower Your Pool's pH
    By PoolDoc in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-18-2013, 03:11 PM
  2. Just painted my old 45 year old fiberglass pool and refilled with well water.
    By gwingard in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-13-2011, 01:00 PM
  3. chalking and painted pool
    By tomdow2 in forum Dealing with Alkalinity and Calcium
    Last Post: 05-26-2007, 09:24 PM
  4. Converting painted rubber coat to epoxy
    By tomdow2 in forum In-Ground Pool Construction and Repair
    Last Post: 04-15-2007, 05:31 PM
