Thread: Hayward H200 wont light.
    Honesdale PA
    Default Re: Hayward H200 wont light.
    Are you sure it isn't just air in the line that has to be bled out? I have an H250 that hasn't been used in years and as I recall, at spring lightup, I would wedge a stick on the button you hold down to light the pilot because I didn't feel like sitting there waiting. I'd just come back 15 minutes or so later and light the thing. The gas flow for just the pilot is so low it could take many minutes to bleed the air out of a long line.
    There should be no explosion issue if the heater is ventilated properly. If you're concerned about that, let it bleed a while, then release that button for a few minutes to let any accumulated gas to disperse, then try and light it normally.
    If this isn't the problem we'll work it more.
    Cleveland, OH
    There was air in the line and maybe i didnt get it all out. I will check this again.
  1. Hayward SP 540 pool light
    By Wes75XT in forum Pool Equipment & Operations
    Last Post: 08-10-2012, 05:19 PM
  2. Hayward LED Light
    By captainron19 in forum Pool Equipment & Operations
    Last Post: 05-29-2012, 03:31 PM
  3. Hayward H200 heater pilot will light but unit doesn't get very warm
    By Joe Stephen in forum Pool Equipment & Operations
    Last Post: 06-20-2011, 10:47 AM
  4. Hayward Light questions
    By KirstenHW in forum Pool Equipment & Operations
    Last Post: 08-15-2007, 05:34 PM
  5. Hayward LED Color Light - Anyone have one?
    By devonmyers in forum Pool Equipment & Operations
    Last Post: 04-06-2006, 12:48 AM
