Thread: AO Smith replacement motor suddenly noisy
    St. Louis, MO, USA.
    Default AO Smith replacement motor suddenly noisy
    About 1 year ago, my pool service company replaced the original Sta-Rite motor on my circulation pump with an AO Smith Centurion B853 (1HP) (after 3+ years of service). I was very happy with it until now because it ran much cooler and quieter than the original. But now, it has suddenly become noticeably noisier - a more pronounced whine that can be heard in the house. I believe it is also running hotter.
    I have been running the pump 12 hours a day since the motor was replaced, where I had been running it 7x24 previously. Any idea what may be happening?
    Rick
    18,000G freeform gunite; PebbleSheen; Sta-Rite System 3 Cartridge; Sta-Rite heater; Polaris AutoClear Cl Generator; Polaris 380 cleaner
    Lightbulb Re: AO Smith replacement motor suddenly noisy
    Please look under the motor/ pump interface for a drip ( this would indicate that the shaft seal assembly has gone bad on you)
    I'll await your response
    St. Louis, MO, USA.
    Default Re: AO Smith replacement motor suddenly noisy
    Good call, Waste. There is water dripping from the motor/pump interface... not a lot, but I can see it when I get on my knees and look underneath.
    So I guess I should contact my pool service company. How serious is this? Does this indicate impending failure?
    Rick
    Honesdale PA
    Since the motor was replaced only a year ago the pump should come apart easily. That is no corrosion seizing bolts and so forth. Replacing the seal assembly should therefore be pretty easy. Dig up the owners manual, online if you don't have it, and instructions should be in it.
    Good Luck.
  1. Replacing the rotating swich on AO Smith Motor
    By hotajax in forum Pool Equipment & Operations
    Last Post: 06-08-2013, 10:11 AM
  2. noisy motor
    By johnfin in forum --cleanup--
    Last Post: 10-08-2012, 09:41 PM
  3. Wiring a 2 speed A.O. Smith pump motor
    By wack70 in forum Pool Equipment & Operations
    Last Post: 08-26-2011, 12:47 PM
  4. Bearing Replacement 1hp AO Smith Motor
    By Spurgeon in forum Pool Equipment & Operations
    Last Post: 05-15-2010, 02:18 AM
  5. Sta-Rite Pump / A. O. Smith motor stopped
    By Longgrove in forum Pool Equipment & Operations
    Last Post: 06-11-2008, 02:34 AM
