Thread: pebble tec
    Default pebble tec
    Our pool is about 5 years old now... or is it six? Our Tahoe Blue pebble tec is really gray now... has anyone else had it fade so much? I wish I would have gone with the sandy color....
    Crowley, TX
    Default Re: pebble tec
    I have Tahoe Blue pebble tec as well. It is going on 5 years old. The only problem I have had with discolor was that I was not doing a good job of stirring the salt around when I put it in the pool. Therefore, I had some brown streaking stains. This spring, I drained the pool...Yikes! Acid washed the pebble tec with a 50% water and 50% Muratic Acid mixture. Looks brand new again. The worst part of it was that I had to refill the pool and start over on pool chemistry but it only took a couple of days and everthing was fine. The acid washing was simple and not that expensive (acid, water, and a strong brush/broom). Only took 3 or 4 hours to do.
    So, I am not sure about your graying problem. But mine is fine.
  1. Pebble Tec Stain
    By bethsg in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-08-2007, 08:17 PM
  2. Pebble Sheen ?
    By jrouse1 in forum In-Ground Pool Construction and Repair
    Last Post: 01-13-2007, 09:37 AM
  3. Pebble-Tek Question...What exactly is it?
    By Enigma869 in forum In-Ground Pool Construction and Repair
    Last Post: 07-30-2006, 12:58 PM
  4. Pebble Tec
    By joedinaz in forum In-Ground Pool Construction and Repair
    Last Post: 07-30-2006, 12:38 PM
  5. New Pebble - first tests
    By dawndenise in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-25-2006, 09:08 PM
