Thread: Replacing liner soon
    Default Replacing liner soon
    Hello-
    I will be replacing my liner in the next week or so. (darn pool alarm ripped the liner over the winter!).
    The pool was originally installed with a sand bottom with sand coving. I think the sand coving has since been washed away. My question is, could I install a foam coving over the sand bottom?
    One other question about draining the pool. I can probably get most of the water out by siphoning with a garden hose. But, how do you get the rest out? Can I poke holes in the liner?
    Thanks!
    Kevin
    24' x 15' x 52" AG Pool
    Hayward S180T Sand Filter/1 HP Pump
    Default Re: Replacing liner soon
    Quote Originally Posted by kjmelak View Post
    Hello-
    Thanks!
    Kevin
    Yup and yup. You can use a foam cove over sand and you'll have to resurface the sand anyway for the new liner.
    Wink Re: Replacing liner soon
    Thanks! I ordered the Gladon original cove kit today. Wish me luck!
  1. replacing liner for the 1st time - do I need padding?
    By lne216 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-30-2013, 08:35 PM
  2. replacing liner need some suggestions
    By poolhelp101 in forum In-Ground Pool Construction and Repair
    Last Post: 03-01-2013, 05:08 PM
  3. Questions about replacing liner
    By AndyT86 in forum In-Ground Pool Construction and Repair
    Last Post: 04-24-2008, 09:33 PM
  4. Replacing a liner
    By TimWillin2 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-23-2007, 11:10 AM
  5. Replacing liner and water
    By brider18 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-20-2006, 04:21 PM
