Jonathan,
Soft limestone is susceptible to getting broken up from splash-out and evaporation from regular pools as well, but it can happen more quickly from salt pools due to the higher salt levels. It may be due to salt recrystallization pressure when salt gets into absorbent stone.
So if keeping a pool with the higher salt levels you need to either 1) seal the stone if it is absorbent, 2) use a hard stone that does not absorb water or 3) regularly rinse the stone with tap water to dilute or wash out the salt.
Even with concrete, you would be better off sealing the stone. We seal our textured concrete every year and seal the non-textured coping at the same time, even though our pool isn't a salt pool. It helps to make the stone/concrete last much longer.
The hardness of stone isn't just based on the type/class of stone, but on the specific quarry from which it is mined. However, limestone is typically a soft stone and is not a good choice around pools in general. Flagstone is mixed, depending on quality. Travertine has to have its small holes filled with synthetic resin or cement, but we still need to reseal our travertine shower every few years. Tile would not absorb the water, but keep in mind that grout is somewhat similar to plaster with some calcium carbonate (like limestone). Marble is hard, but expensive.
I suggest you talk to an experienced vendor that deals with various stones and is familiar with water absorbency.
Richard
