Thread: Question on Reel & Solar Cover
    csevel is offline Registered+ Thread Analyst csevel 0
    Cleveland, OH
    Default Question on Reel & Solar Cover
    Duplicate post..but need any response. UNACCEPTABLE ACTION--CARLD, MODERATOR.
    I have an inexpensive Feherguard surface rider solar cover reel that I bought when my pool was new....it's never been out of the box. We purchased a heat pump last year and I would like to retain heat at night. My question is whether a 12mil solar cover will be too heavy for the reel. The instructions say the warranty will be void if I use more than an 8mil cover. I'd like to purchase the clear 12 mil cover but am afraid the weight might weigh the reel down too much... Anyone have any advice??
    Claudia
    18' Echo Canyon A/G Pool by Artesian
    8500 gallons
    3/4hp Jacuzzi 2-speed pump - Cartridge Filter
    Default Re: Question on Reel & Solar Cover
    It may well break it. Solar reels made out of plastic have plastic roller bearing, not proper ball bearings or metal caged roller bearings, so they get torn up with usage.
    An 8 mil SC is pretty light, and you'll get 2, maybe 3 seasons out of it before it will need replacement. A 12 mil will last 3-4, max, and a 16 mil won't last any better. However the heavier covers do insulate better, IMHE.
    So your choices are pretty straight forward: Get a metal solar reel, or, get an 8 mil SC, or don't worry about the warranty and use what you want.
    I have deleted your second copy of this thread.
    DO NOT POST A THREAD MORE THAN ONCE! WE DO NOT ALLOW IT AND WILL DELETE ANY DUPLICATES. WE ARE ADAMANT ABOUT THIS RULE.
  1. Solar Cover Reel
    By chinewalker in forum Above-Ground Pool Construction & Repair
    Last Post: 08-23-2014, 06:35 PM
  2. Solar Cover Thickness, Reel Quality, Solar Panels
    By vector13 in forum Pool Equipment & Operations
    Last Post: 03-20-2012, 02:45 PM
  3. what is the best Solar Cover Reel
    By Billybob in forum Pool Equipment & Operations
    Last Post: 08-15-2011, 11:43 PM
  4. Solar Cover Reel
    By jrv331 in forum Above-Ground Pool Construction & Repair
    Last Post: 08-13-2007, 03:40 PM
  5. Stupid Solar Cover Reel Question :)
    By OhAllWet in forum Pool Equipment & Operations
    Last Post: 07-17-2006, 02:49 PM
