Thread: New Pool Water Has Funny Taste
    haneyrm is offline ** No working email address ** haneyrm 0
    Tampa, Florida
    Default New Pool Water Has Funny Taste
    Hello All,
    We just completed construction on a 15,000 gallon inground Pebble-Tec pool in Central Florida with a SWG system. Like way too many others, my pool builder left me with a test kit and a handshake. I took a water sample to my local big chain pool store and $100 in chemicals later ended up with muriatic acid, calcium hardener, stabilizer, metal treatment, and one or two other things. The nice lady told me that my pool had no stabilizer what-so-ever in it. I was having an impossible time getting the chlorine level up and was running 65% on the SWG so I guess she was right. Now, my PH is about 7.8 and my chlorine is above 3.0. I have my SWG set at 15% and the chlorine is still off the chart. I do not know if the pool was ever shocked. I do not smell or taste any chlorine at all.
    This may sound odd but my water has a bad taste to it. My salt level is around 3300 but I do not think it is salt I am tasting. The water does not taste clean if that makes sense. Would shocking it make the water taste better. Our last pool did not have a SWG and the water tasted and smelled great. Any help would be greatly appreciated.
    Thanks,
    Mike
    Ft Lauderdale, Fl
    Default Re: New Pool Water Has Funny Taste
    Have your water tested for TDS, which is different from salinity. Usually high TDS is as a result of high calcium and magnesium salts, metals in the water, and other "Dissolved solids". Usually high TDS is indicated by needing a higher chlorine level to maintain the pool, a dull appearance to the water and the salty, metallic taste to the water. The only way to reduce high TDS is dilution.
    How do you know if you have high TDS? Take a water sample of the pool water and the source water you use to add water to the pool and have them both tested.
    First, you have to factor out the salinity. This is done by testing TDS and Salinity and subtracting the salinity out of the TDS (which should be higher).
    Second, test your source water for TDS too. If this is well water, your TDS will probably be higher.
    Third, the difference between the source water and the TDS test should not be more than 1000 ppm different. If so, you have high TDS.
    Dilution is the solution.
    It will also help if you can have them do a complet test and report the result here.
    Total Alkalinity
    Calcium Hardness
    pH
    Cyanuric acid
    Free Chlorine
    Total Chlorine
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
  1. Funny story about me, a first time pool owner
    By Wraypau in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-22-2012, 10:00 PM
  2. Bad taste in water and burning eyes
    By Gizmobyte in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-06-2006, 10:03 PM
  3. Funny pool prank.
    By cruzmisl in forum General Interest
    Last Post: 07-14-2006, 02:58 PM
  4. Can you taste and feel SWG treated water?
    By aquarium in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-22-2006, 03:28 PM
  5. TDS test at pool store? Salty taste in water??
    By Henrys514 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-20-2006, 01:03 PM
