I apologize for the long thread but I can't seem to shorten it.
Now that I buy the bigger jugs of 6% bleach (which are much more difficult than the 1 gallon jugs to guestimate when adding to pool), I wanted to put in writing several scenarios for increasing or maintaining my pool's chlorine level for use at home, e.g., how many double cups to raise FC by about 3 ppm which is what I usually lose on a sunny day with 50-60 ppm of CYA (I don't dare go lower than this). My pool's still covered but I will be uncovering it in the next week or two so last night I ran the pump awhile and took a water sample from the skimmer. I should mention that I had a new liner installed last September and continue being perplexed why the water still can't seem to hold a chlorine level with a solid winter cover on it. I never used to have this problem with the "old" water -- it would only drop from 15 ppm to about 8 ppm over 8 long months. Anyway, no surprise when I checked last night, the CL was again at zero.
So last night I added an entire 2.46 jug of 6% bleach and let the pump run overnight; I also added yet another box of Borax as I also can't keep my pH up -- conversely with the "old" water I had to add acid because pH would creep up constantly.
This morning the CL reading was 4.5. I'm at work now and have access to the pool calculator so I plugged my baseline and target CL numbers in and hit calculate with respect to using 6% bleach. It tells me I should add 187 ounces of bleach to raise it from zero to 4.5 ppm. Yet by my math, the 2.46 jug I used would amount to 302 ounces based on 128 ounces being in a gallon x 2 + the 46 ounces = 302 ounces. I suppose it could be possible that the CL was actually higher last night and simply dropped to 4.5 by this morning which could make sense (and give me more faith in the pool calculator) but, otherwise, I'm not sure I can trust the pool calculator. Of course I suppose it's also possible the gallonage of my pool is not exactly 20,000 gal like I was told by previous owners; I was told it was 9 ft. deep but the liner installer said no, it's 8.5 feet deep. Lots of variables I guess, but what's really eating at me is why, since I got the new liner and then covered it with a winter cover just a few days later last September, I have not been able to keep chlorine in the pool or keep my pH stable all winter. I just find it very hard to believe there's an algae bloom, and the water sample I took certainly is very clear. At the cost of Borax it will be very defeating to have to add this regularly to keep the pH up, not to mention not being able to keep CL in the pool.
In the midst of my perplexion, having browsed this great forum for a number of years now, the only answer I can see for not being able to hang onto chlorine in a covered pool would be because of algae, yet it just doesn't make sense when for 6 years prior I never had these issues.
Could the pH issue be related to the CL issue? If I can't keep CL the pH drops?
I want my old water back! ;(
***By the way, as a member I could not access this forum at the same time there were issues related to the "Where are the Moderators" thread (which is closed). I have been wondering when this site might fall to never be resurrected because of the original owner MIA. Has something occurred where it is now here to stay? I know there's the Trouble Free site, but of course this forum will always feel like home to me, and I'm sure to many others, certainly including all the great Mods.***
