Results 1 to 9 of 9
Thread: air in return jets and my ordeal
    Honesdale PA
    Default Re: air in return jets and my ordeal
    In order of pricyness:
    Boat shops
    Harley shops
    Pool stores.
    Glad you finally got it fixed.
    Feel free to vent any time.
    Quote Originally Posted by Poconos View Post
    Boat shops
    Harley shops
    Pool stores.
    You forgot Mercedes and BMW stores......
    The first year when the pool company opened my pool, they put something on the plastic plugs before they screwed them into the pump. It was thick like caulk and dried into a hard rubber glob. at the end of the season when I unscrewed the plugs the I could just pull the glob of stuff off.
    any Idea what they put on the plugs?
    Honesdale PA
    My guess is silicone seal. Forms a good thread seal and can be peeled off like you said.
    Quote Originally Posted by sunofthebeach View Post
    Plumbers putty.
    I'm with Isshin on this. I use silicone grease on my o-rings and plugs at the end of the season and they don't get that plug. But the plumber's liquid on the solar panel connections does.
    I started thinking about it and it's called plumber's dope. Plumbers putty is the stuff they use to mount sinks and stuff.
    Jun 2010
    Default
    I had air for a year and it ended up being a brass anchor from my winter cover lodged in the suction line where it made a 90 degree bend.
    By the way, I had to cut a 1ft square dig down to the elbow cut the line to remove it.
  1. Air from return jets
    By cdsn99 in forum In-Ground Pool Construction and Repair
    Last Post: 04-25-2012, 06:33 PM
  2. Air bubbles in return jets
    By fog80 in forum Pool Equipment & Operations
    Last Post: 07-01-2010, 10:21 PM
  3. Spa return jets where to buy?
    By john509 in forum In-Ground Pool Construction and Repair
    Last Post: 06-05-2010, 12:04 PM
  4. SWG and return jets.
    By court475 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-25-2010, 03:11 PM
  5. Air Bubbles in the Return Jets. My Fault?
    By ccostan in forum Pool Equipment & Operations
    Last Post: 05-26-2007, 05:39 PM
