Thread: Will 1.5 HP Pump 80 Feet (Solar Heater)
    Default Will 1.5 HP Pump 80 Feet (Solar Heater)
    We are putting our solar panels on the roof today. Just worried there will not be enough pressure to pump it up to the porch roof. Does anyone have any info to offer. We have it on our fence now but it does'nt get enough sun. We could slant it out for a more direct sun hit but the roof would be better. The pump is 1.5 HP model (SP1593) Haywood Power-Flo Matrix for a 18 foot aboveground.
    Default Re: Will 1.5 HP Pump 80 Feet (Solar Heater)
    I'm not the pump expert but I think it should be fine, if the pump roof isn't too high. I have solar panels and a 1hp on a 40x16, but they are only about 4-5 feet above the pump.
    If the 1.5 hp is full-rated, you definitely should be OK. There may be some plumbing issues, but that's better handled by some other people.
    Honesdale PA
    You should be OK. Remember that once the system is full of water you don't require any more pressure to circulate the water on the roof than with the heater on the ground. The suction on the downside equals the pressure needed on the upside. You need the push to get the water to the roof initially.
    mas985's Avatar
    Pleasanton, CA
    Maximum head for that pump is a little over 50 ft so as long as the roof is lower than that, you should be ok.
    Mark
    apopka, florida.
    Quote Originally Posted by mas985 View Post
    Better install a vacuum break on the highest connection to allow the water to drain when the system is off. If not, when the pump is off the sun will heat the collectors while they are under vacuum and the collectors and piping can all be damaged.
    If you live in one of the colder climes then the system must be drained anyway before the cold weather settles in.
    Central Florida Swimmer
  1. Can an over-sized pump cause my Game Solar Pro heater to fail?
    By Tray85 in forum Pool Equipment & Operations
    Last Post: 07-01-2013, 04:07 PM
  2. Replacing Solar thermal and natural gas with Solar PV and electric pool heater
    By California Newbie in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 08:14 PM
  3. solar heater
    By alexstjo in forum Pool Equipment & Operations
    Last Post: 06-03-2011, 03:38 PM
  4. Solar heater location and pump question
    By pettinej in forum In-Ground Pool Construction and Repair
    Last Post: 06-10-2008, 08:08 AM
  5. Hard Pipe my pump and solar heater
    By MaxxFusion in forum Pool Equipment & Operations
    Last Post: 05-22-2008, 07:14 PM
