FC 1.5
PH 6.8
ALK 120
CAL 60
CYA 80
The pump had only been running for 1 hour before the rain started, so I'm wondering what will happen tomorrow after a good long pump run. I also didn't fill it up to where it should be due to our chance of rain over the next two days. It's maybe 2" over the skimmer...right where the pump runs fine and the skimmer doesn't make gurgling noises.
CAL was 60 for sure. I measured with my 10000% WHITE LED flashlight and I could full see the color change. I guess the sun's yellow tint didn't allow me to see that before.
CYA was done with the flashlight and inside and I think the lighting isn't right to read it effectively as you are supposed to do it in sunlight. So I hope that goes down after longer pump running, a touch more water, and a sunny outdoor reading. I'll not be a happy camper after dumping 10,000ish gallons of water to not see a change.
Anyways, I added nothing and turned the pump off for the night. Tomorrow, weather depending, I will run the pump for 3 hours at least. I will probably dump in 1 big jug of Walmart Bleach and my last 2 boxes of Borax. Then retest to see if my ALK change helped my pH ability. So unless anyone has further input that's what I'll do tomorrow if the rain cooperates.
...not a problem )
