Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Continually leaking vinyl pool… Pool cleaner at fault?
FAQ
register
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
04-11-2009
09:18 PM
#2
JohnT
View Profile
View Forum Posts
Registered+
Verb Herder
Indiana.
Re: Continually leaking vinyl pool… Pool cleaner at fault?
How old is the liner? My first guess would be that the liner is shot.
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
Anyone have the new Baracuda X7 Quattro?
Dolphin Diagnostic Review
Robotic cleaner for vinyl in ground pool
By jules0804 in forum Pool Cleaning: Manual or Automatic
4
Last Post:
06-20-2012,
01:54 PM
Best vacuum cleaner for vinyl inground pool?
By Thorsdag in forum Pool Cleaning: Manual or Automatic
3
Last Post:
06-16-2011,
11:27 PM
Leaking IG Vinyl Pool
By drbob101 in forum In-Ground Pool Construction and Repair
1
Last Post:
05-22-2007,
05:59 PM
safe depth to drain vinyl pool w/vinyl stairs
By ScottsdaleSwim in forum Testing and Adjusting Pool Water Chemistry
17
Last Post:
07-13-2006,
01:47 AM
Vinyl Coping for overlap IG vinyl pool
By SLS in forum In-Ground Pool Construction and Repair
6
Last Post:
06-22-2006,
09:57 PM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
