Re: adding muriatic acid to covered swg pool
Main reason the pH rises is because of outgassing of CO2. There are several ways to minimize this:
Make sure the CYA level is high enough (usually around 80ppm) minimize cell on time and the generation of hydrogen bubbles that out gas CO2
Keep the TA on the low side (perhaps as low as 60 or 70 ppm) to keep the carbonation level of the pool down so there is less outgassing of CO2
Keep aeration to a minimum. If you have water features that aerate the water such as waterfalls, spillovers, deck jets, or fountains do not run them all the time but only when you are entertaining or using the pool.
Do NOT drop the pH too low. Try not to go below about 7.5-6-7.6 when you lower pH. Remember, the lower the pH the faster the outgassing of CO2.
Keeping a cover on the pool can help minimize CO2 outgassing and keep the pH from rising as fast but remember that the pool does need to be undcovered from time to time so chlorination byproducts can gas off.
Add borates to 50 ppm to introduce a secondary borate buffer. This, along with a TA on the low side as noted above, can help stabilize ph at around 7.7 for long periods of time.
