Thread: PayPak Service Diagnostic Codes
    St. Louis, Missouri
    Default PayPak Service Diagnostic Codes
    I have a 3-4 year old Raypak RP2100 335 heater that has suddenly stopped working. It won't spark properly to ignite the natual gas. It worked fine for the first 2 weeks of this season, then stopped.
    The front panel error is "PLT". Also, I can hear that the clicking sound of the ignitor inside has stopped.
    There's supposed to be a board inside that has a lights which indicate the exact problem -- service diagnostic codes. Does anyone have a list of these codes and what they mean available?
    [I keep the pH above 7.2, its definitely getting gas as I can smell it (and like I said it worked for a couple of weeks), and I've completely cut the power several times to no avail.... I think this is a problem with an internal part since its pretty new -- not a problem with dirt build-up, etc.]
    Thanks,
    -Craig
    IMherDad is offline ** No working email address ** IMherDad 0
    Memphis, TN.
    Default Re: PayPak Service Diagnostic Codes
    Sounds like the igniter has gone out. My suggestion is to call the company.
    (805) 278-5300 RayPak Customer Service
    Sacramento, CA, USA.
    The "PLT" error code means pilot failure. The lack of spark may or may not mean an ignitor problem.
    I have seen the "PLT" code come up because the main valve in the heater was in the "off" position. No gas = no pilot. Have also seen clogged pilot-burner orifices. The lack of spark may have to do with water flow issues (dirty filter, clogged basket, etc.), or it may be a problem with the electronics of the heater.
    All of these (except turning the gas valve on) will require a competent service tech to diagnose.
    St. Louis, Missouri
    So, its now 2 years later (the unit is about 5 years old) and I now have mulitple failures on the piece of crap.
    According to our pool company:
    1) Pilot module is out and needs to be replaced.
    2) Wiring is shot, probably due to flame-ups
    3) The bottom spreader pan is rusted almost completely and needs to be replaced.
    Total tab to fix this $2700 heater -- $1300 bucks.
    NEVER EVER buy a RayPak.
    - A very upset owner...
  1. Jandy aquapure 1400 service codes 120-121
    By Tomfinch in forum Pool Equipment & Operations
    Last Post: 04-30-2012, 07:20 AM
  2. Dolphin Diagnostic and freezing weather
    By SandyDittmer in forum Pool Cleaning: Manual or Automatic
    Last Post: 09-25-2009, 07:48 PM
  3. Dolphin Diagnostic Review
    By HHead in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-28-2009, 12:24 AM
  4. Dolphin diagnostic advantage-differences?
    By luvapool in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-27-2006, 12:26 PM
