Closed Thread
Thread: Help !! Need assistance Fast !
    xoroniox is offline Registered+ Thread Analyst xoroniox 0
    South Florida
    Default Re: Help !! Need assistance Fast !
    I am not an expert at building pools but i do know this pools are NOT supposed to leak! Before they move on to the next step i believe you should talk to the builder show him exactly where it is leaking and talk to him about it. if it leaks now and they are done with the shell of the pool itself acid wash/filling the pool will not seal the leaks. I hope someone can direct you better than i have considering i have never had a pool build before, but what you tell me at your stage just doesnt seem right. good luck
    -Arron
    The plaster company should not have plastered if the pool was weeping water thru the shell. The weepers should have been taken care of before plastering the pool. The plaster may eventually stop the weeping water but you could end up with bonding problems and discolored plaster in these areas. Not a good way to start out.
Closed Thread
  1. New to the forum and in need of assistance
    By tideman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-21-2011, 05:34 PM
  2. Need help fast
    By Sumo1 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-20-2009, 05:17 PM
  3. Can cya go down that fast?
    By DanS in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 11-14-2007, 09:50 PM
  4. Need help fast
    By Sumo1 in forum Dealing with Algae & Slime
    Last Post: 05-18-2007, 10:02 PM
  5. new pool to be - assistance please!
    By shrike in forum In-Ground Pool Construction and Repair
    Last Post: 12-25-2006, 04:30 PM
