Quote Originally Posted by cleancloths View Post
You might try throwing in some Downey fabric softener. No, I'm not joking. I own a laundromat, and when customers put to much soap in a washer we add some fabric softener and it kills the suds.
Actually, this is not a crazy as it sounds. The detergents are basically anionic surfactants, usually SLS and related sulfates (negatively charged) and the fabric softener is basically cationic surfactants, which have a positive charge (and very similar if no identical to some algaecides used in pools) so instead of fabric softener I would use a cationic algaecide like a linear quat (benzalkonium chlorides and other akyl chlorides) or polyquat to reduce the sudsing. Linear quats do suds on their own but should neutralize the sudsing of an anionic surfactant and vice versa just like fabric softener (or hair conditioner, also based on quats) does. .
I would then use a very strong dose of enzyme product to break down whatever can be broken down and then shock to oxidize after giving the enzyme time to work, perhaps a few days.
(yes I realize that this is an old thread that was hijacked with someone asking about BBB for spas but cleancloths WAS onto something that has the chemistry behind it to back it up!)
