Thread: Air in system won't let pump hold pressure (Skimmer weir stuck)
Threaded View
  1. #5
    Default Re: Air in system won't let pump hold pressure
    As it turns out, the problem wasn't around the basket or the pump. It was even more simple than that, but wasn't something I had come across before so I never thought to check it. For some reason, the flap {Admin => "skimmer wier} in front of the skimmer that is supposed to open when the water flows was sticking closed. When the pump basket would finally fill and the pump would start to pull water, it would only pull what was in the line back to the skimmer basket, then start sucking air b/c the skimmer couldn't pull water from the pool. The pump would run dry, then the water would slowly leak back into the skimmer until it filled, allowing the pump to run, but only long enough to drain the water again.
    Anyway, not sure why it started to stick closed, but I shaved the sides down a little, put it back in and everything is working perfectly.
    Thanks for taking the time to reply to my questions. PoolForum is great.
  1. Cannot figure out how to install a Hayward Skimmer Weir
    By Casey in forum In-Ground Pool Construction and Repair
    Last Post: 07-20-2011, 10:17 PM
  2. Is skimmer weir removable?
    By dawndenise in forum Pool Equipment & Operations
    Last Post: 08-28-2009, 02:29 PM
  3. Tab on skimmer weir broken
    By trauh in forum In-Ground Pool Construction and Repair
    Last Post: 08-10-2007, 08:12 PM
  4. Skimmer doors stuck
    By rosrud in forum In-Ground Pool Construction and Repair
    Last Post: 08-01-2006, 08:46 PM
  5. Changing the weir gate in a Jacuzzi PMT skimmer
    By davegs in forum In-Ground Pool Construction and Repair
    Last Post: 06-11-2006, 11:46 PM
