When the pump turns on, there usually isn't water in the basket in front of the pump. It runs for about 30 seconds, the fills with water and then the pump runs normally. There is big "burp" when the water starts flowing into the pool, but I didn't think it was a big deal. This morning, I turned the pump on and it operated as I described, but about 5 seconds after the basket filled completely and the pump started running, the basket completely drained of water and no water was being pulled from the pool into the pump.
I tried it again and opened the pressure valve on top of the filter, but that didn't make a difference. Thinking that the filter could somehow be clogged, I tried to backwash but there wasn't enough pressure to make it work. Next step was to take the filter apart, remove the grids, hose down, reassemble filter and start again. After all that, same problem exists. I checked the o-ring on the filter while I had it open and it was okay. I've opened and closed the clear top of the filter basket to make sure it is sealed tightly, and it seems to be.
There's nothing blocking the skimmers, and the water will flow in the system for a couple of seconds before the basket empties, pressure drops and pump starts sucking air again. HELP! It is July 4th and I'm can't keep the pump running b/c I don't know what is wrong.
