Pump run time is based on your turnover which in turn is based on the pump head curve.
First, determine the head loss for your plumbing. A rough estimate is to take your PSI from the filter and multiply this by 2.31. If you do not have a suction gauge (multiple in. mg. by 1.13), add about 10' of head for suction head.
Second, look up the the flow rate from the pump head curve. Usually in the pump manual.
Third, use the formula turnover (hrs) = Pool Volume (gallons) / (gpm * 60)
Fourth, set your run time to 1 or 2 turnovers depending on the swimmer load. I usually set mine for 1 turnover for very low swimmer loads and 1.5 turnovers for higher loads.
