Thread: De Filter Joint retainer
    Exclamation De Filter Joint retainer
    My DE filter has had a broken joint retainer and for over a month the pumps have not turned. The pool supply warehouse is unable to find the part, they already ordered two wrong ones.
    What I know,is that the filter is over 15 years old, it is a NAUTILUS FNS ,and made by PAC FAB. The circumference is 59 1/2 inches and the height is 39 inches from the middle of the pressure valve to the black base. All of the serial and model numbers are no longer readable. I would appreciate help with this matter, if anyone has had a similar problem. I will also forward pictures of it to you, if that helps.
    Thanks in Advance,
    SML
    Default Re: De Filter Joint retainer
  1. Replies: 0
    Last Post: 12-24-2012, 04:16 PM
  2. Sand Filter and Cartridge Filter Owners Please Advise
    By amati5 in forum Pool Equipment & Operations
    Last Post: 08-30-2011, 06:05 PM
  3. Replies: 7
    Last Post: 05-16-2010, 09:46 AM
  4. Expansion Joint Necessary?
    By jkapit in forum In-Ground Pool Construction and Repair
    Last Post: 09-29-2006, 12:20 AM
  5. Help finding E ring retainer
    By rockg in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-08-2006, 03:44 AM
