I have the ez vac and it does a good job, it cleans about 85% of the pool. It does get stuck on the ladder.
It does get bothered by the currents in the pool (the return) and I usually have the return shooting up breaking the surface to avoid underwater currents. It comes with a replacement return that's a 90º angle to the pool wall but I'm too lazy to replace my normal return.
I have used it to clean a green pool floor and it does a great job where ever it passes. What usually happens is I put it in the pool, run it for about 3 hours, keep tabs on it to make sure it's not stuck under the ladder and clean the remaining 15% by guiding it to those spots.
I would think any pool cleaner would get stuck in an AG pool unless you remove the ladder.
