Results 1 to 8 of 8
Thread: Borax test Strips and cloudy water
    Default Re: Borax test Strips and cloudy water
    I have no knowledge about with a cartridge filter, but in a sand filter, when you add DE, you don't get an immediate rise. It takes a while. I learned that the first time I added DE to my sand filter. I added some, saw no pressure change, added more, no change, added more, ............... Then, awhile later, I had a plugged filter and had to backwash.
    good information !
    I have tried the DE with my Pentair cartridge, (it is a 50 size ... ) could DE get through a good cartridge (almost new) and get into pool ?
    It was put it in skimmer, maybe the DE stayed in the cartridge but my pool still was cloudy from algae or water mold.
    Looks that cellulose fiber is a better choice for cartridge filter enhancement ?
    Also, I have a slime filter bag that works really well but the on & off of it would be better suited to the cartridge filter & cellulose fiber if that works well?
    I am bringing up my borax levels to 40 ppm and balancing my PH & TA & CL since I survived the algae and floating lint "a water mold?" with shocking and look forward to a clear pool.
    This forum seems to be better that the best pool store advice that is a good thing !
    Thanks.
    deep_blue
  1. pool test strips vs dropper test kit
    By sputterbug10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2012, 11:23 PM
  2. test strips
    By hmc38 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-16-2011, 05:50 PM
  3. Test strips
    By Seahorse in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-05-2011, 06:12 PM
  4. Test Strips: really that bad?
    By rifraf in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-23-2006, 10:39 PM
  5. test strips
    By marshallg in forum DPD-FAS based testing
    Last Post: 04-27-2006, 10:06 PM
