Results 1 to 10 of 18
Thread: No Chlorine. . . If not Algae, then What?
    Pamsel is offline Registered+ Thread Analyst Pamsel 0
    Central Illinois
    Default Re: No Chlorine. . . If not Algae, then What?
    Thanks for the info Carl. We have an Aquabot Turbo. It does a pretty good job but spends a little too much time on the sides and seems to not get dirt that's collected right in the curve where the sides meet the bottom. I didn't know that I don't need to be running the filter while the Aquabot is going. I normally run the filter all the time.
    Pam, Illinois
    "17'x33' oval 14.5K gal IG vinyl pool; liquid chlorine; Hayward Pro Series, M-S-244T sand filter; A.O. Smith Centurian, Switchless, 1.40 HP pump; Right now 24/7hrs; Pool Solutions PS234
    Serial #6511, Drops / Powder; Community well; summer: none; winter: mesh; ; PF:8.3"
    Quote Originally Posted by Pamsel View Post
    Pam,
    One of the diagnostics for these gadgets when they aren't working perfectly is to turn OFF the filter while it's running. The moving water can offset and upset how the robot finds its way around the pool. They don't actually seem to have sensors in them--so my guess is that the controlling computer reads a change in power requirements from the motors (voltage/amperage draw changes) and figures it's run into something and then uses THAT as its senser information. Clever and logical!
    Having had my Dolphin apart, and the Blue Diamond being more open inside, I see that the B/D has three drive motor each 3x the size of the ones in the Dolphin, yet it's a much lighter unit. So far, it's been much better for me.
    Happily, my Dolphin is now my friend's Dolphin and it's working much better for him.
    The Aquabots have a good rep, too.
    Central Illinois
    Thanks once again, Carl. You're a wealth of information! I do appreciate it. From now on I will turn off the filter when I use the sweeper and see how it works. It's a world better than the little cheapie that was here when we bought the house, so I still like the Aquabot...just those couple of issues that could be improved. I'll see if it changes with the filter off.
    Happy Summer days to you! You're a great guy - spending your time helping people like me! Glad your old Dolphin is working well for your friend. It always feels better to pass along something to someone else who can use it, rather than let it end up in a dump somewhere!
    Pam, Illinois
  1. Chlorine high and Ph low but the algae is gone...now what?
    By karenib in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2013, 08:23 PM
  2. chlorine/algae problem
    By kaufmh in forum Dealing with Algae & Slime
    Last Post: 06-10-2011, 01:14 PM
  3. Why algae killers other than chlorine?
    By Flash73 in forum Dealing with Algae & Slime
    Last Post: 05-29-2011, 08:52 PM
  4. Frustrated with algae and chlorine
    By mnhwinn in forum Dealing with Algae & Slime
    Last Post: 07-31-2010, 02:34 PM
  5. black algae and chlorine
    By joecus in forum Dealing with Algae & Slime
    Last Post: 06-14-2010, 06:13 PM
