I have an in ground pool and spa. When I turn on the spa by changing the Jandy inlet and return valves, water comes out of the air pipe for the jets. I have no idea where to look. I have changed one check valve. I have two on the return side and one on the inlet side. Could it be one of these other check valves?
Thank you
Jim
