Thread: Chemical Age
    mohawk is offline Registered+ Thread Analyst mohawk 0
    Minneapolis, MN
    Default Chemical Age
    I have different chemicals-all in dry form-that I received from the pool store when we purchased our pool. Most have never been used and was wondering how long dry chemicals last? Some are pucks others are the usual things you get from the pool store with a new pool. I was thinking of putting them in my garage sale if they're still good. Thanks, Denise
    Default Re: Chemical Age
    The pucks will be okay as long as they have not been exposed to moisture--if there's any indication of bubbling or bowing on the lid of the container, then they've gotten moist and have begun releasing gas.
    If the other stuff is less than a year or so old, it's probably okay....I'd buy it if it were still sealed, if I needed it...at garage sale prices, if only half were still effective it's still cheaper than retail!
    Minneapolis, MN
    GREAT! Extra money for me. Denise
    Brookline, MA USA
    Quote Originally Posted by mohawk View Post
    If these are kept dry and sealed they will be good indefinitely:
    Sodium carbonate and bicarbonate, dry acid, calcium chloride, calcium Hypo, tri-chlor pucks.
    I wouldn't store chemicals in the garage. If they spill or mix you're in trouble.
    BTW, did they sell you POPP?
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP
    38 SF DE filter, 1 HP Hayward Super Pump
    Raypak 350k BTU Natural Gas Heater and solar cover
    8 gal Liquidator with bleach
    Dolphin robotic cleaner
    Taylor k-2006 test kit
    Minneapolis, MN
    What is POPP?
    Brookline, MA USA
    What is POPP?
    LOL...
    This is the most important ingredient that pool supply houses can't sell you:
    Pool Owner's Patience and Persistence.
    22k Gal gunite IGP
  1. Chemical Help
    By mreesept in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-20-2012, 12:58 PM
  2. Need Chemical Advice
    By vvon66 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-07-2012, 09:36 PM
  3. chemical levels seem ok?
    By GerriLeAnne in forum DPD-FAS based testing
    Last Post: 07-24-2010, 02:12 PM
  4. CYA: Chemical OR Organic
    By stma in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2008, 03:44 PM
  5. PH Testing Chemical
    By jrv331 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-26-2008, 07:23 PM
