Results 1 to 10 of 12
Thread: Is copper pipe OK?
    Default Re: Is copper pipe OK?
    The corrosion inhibitors vary but are usually phosphates or silicates and they also adjust pH and the level of carbonates (mostly for buffering). For example, when fluoride is added to drinking water, it is often in the form of fluorosilicates with the silicate portion being a corrosion inhibitor. The amount of these substances is small and does not have evidence of causing cancer. Believe me, the people analyzing water systems are pretty particular about what they put in which is why they use multiple steps of sanitation to minimize chlorine disinfection by-products.
    It's also relatively simple to use a decent charcoal-based water filter to eliminate the chlorine or monochloramine as well as other substances from the water. We use one at home, mostly because my wife can't stand the taste of the water otherwise (she's got very sensitive taste). Personally, I don't like the taste of water even if it's distilled (which has no taste), but then I'm weird.
    Richard
    Brookline, MA USA
    Richard
    Then, maybe you like the taste of distilled Highlands single malt Scotch Whisky?
    As to water - have you tried Evian?
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP
    38 SF DE filter, 1 HP Hayward Super Pump
    Raypak 350k BTU Natural Gas Heater and solar cover
    8 gal Liquidator with bleach
    Dolphin robotic cleaner
    Taylor k-2006 test kit
    Ft Lauderdale, Fl
    Someone mention single maly scotch?
    I'm partial to 17yr old Glenlivet. smooooth.
    Copper has been used in commercial pools for YEARS, but as mentioned, not common these days.
    You may try researching Pasco Ram Bit. A little expensive but can do what you're looking to do.
    Sean Assam
    e-mail: sean@teamhorner.com --- www.autopilot.com - www.aquacal.com
    Brookline, MA USA
    Quote Originally Posted by Poolsean View Post
    Anyone who's above the 15 year line deserves some respect, as far as I’m concerned
    I ended up using a 1" PVC pipe. After I shaved its OD down a bit with a belt sander, I was able to shove it inside my old return and from then on used standard adapters to build up my eyeball returns.
    22k Gal gunite IGP
  1. Repair PVC pipe?
    By Steve C. in forum In-Ground Pool Construction and Repair
    Last Post: 08-05-2011, 07:33 PM
  2. Buried Pipe
    By BigDave in forum Above-Ground Pool Construction & Repair
    Last Post: 07-14-2011, 10:20 AM
  3. Transition to/from copper pipe to PVC?
    By Socal_biker in forum In-Ground Pool Construction and Repair
    Last Post: 08-01-2006, 06:26 AM
  4. Leaking pipe
    By mhnewcomb in forum Pool Equipment & Operations
    Last Post: 06-22-2006, 03:23 PM
  5. Can I glue a threaded pipe into a smooth pipe??
    By adl6009 in forum In-Ground Pool Construction and Repair
    Last Post: 06-20-2006, 11:19 PM
