Results 1 to 10 of 12
Thread: Clorox outdoors
    Default Re: Clorox outdoors
    Until you get some cya in there, you're not going to be able to keep any chlorine in your pool. You can buy some cya (also called cyanuric acid, isocyanuric acid, stabilizer or conditioner) at a pool store and add enough per package directions to get to an intial reading of about 30-35. It takes awhile to dissolve so after you add it, wait a week before testing for it or adding more or else you may end up with more in there than you want. You can either add it slowly to your skimmer while the pump is running or put it in an old sock and hang it in front of a return jet or set the sock in the skimmer. (If you do add it directly to the skimmer, like I do, do not backwash until it dissolves or else you will just be throwing it right out.)
    Until you begin to get a cya reading, you'll probably need to test your pool at least twice per day and each time add bleach. After you get your pool cleared and get some cya in there, you'll be able to just test it and dose it in the evenings.
    I would also suggest raising your ph a little with some borax.
    Thanks for your help.
    Is there somewhere on the forum that tells me how much Borax to add and how much it will raise the numbers? (and the bleach). (I know I've seen it somewhere but I can't seem to find it again. ) I know on the back of the big bag of Baking Soda it tells the numbers, and on the stabilizer it tells, but the Borax I'm not sure about.
    Thanks again so much,
    Kerrie
    Here's the bleach calculator you've probably seen before..
    http://troublefreepool.com/files/BleachCalc262.exe
    There's not going to be a rule of thumb for the Borax to raise pH, though--how much you have to add to raise your pH by a given amount will depend on your alk level--the lower the alk level, the easier the pH is to move.
    My alk level is about 170, and my ph is about 7.2 still.
    Should I start with like a cup full or a box?
    Thanks again,
    Kerrie
  1. Greetings. Thanks. Clorox?
    By cayenne in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-05-2012, 05:02 PM
  2. Clorox Outdoors Now what??
    By kerweb in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2012, 09:21 AM
  3. Autopilot installed outdoors??
    By Sardian in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-14-2006, 12:36 AM
  4. clorox
    By rainhill in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-26-2006, 01:48 PM
