Results 1 to 4 of 4
Thread: need tips on vacuuming out sand
    Default need tips on vacuuming out sand
    A broken stand pipe in my sand filter ended up spewing a lot of sand into the pool this spring.
    Regular vacuuming just pushes it around. Any tips out there?
    Default Re: need tips on vacuuming out sand
    Have you repaired the filter? Until you do vacuuming isn't going to accomplish much If you'd tell me exactly your vacuuming procedure, I'll give my input on how to get the dang sand out of the pool
    If your vacuum is actually working, then you need to direct the output to waste rather than back in the pool.
    Got it done. Opened up the skimmer supply all the way and cut the main drain supply back. This was enough to quickly remove the sand without just pushing it around.
  1. any tips to find a leak?
    By dalejanus in forum Above-Ground Pool Construction & Repair
    Last Post: 05-17-2013, 09:37 PM
  2. vacuuming sand in pool...
    By resp215 in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-05-2011, 03:27 PM
  3. Thanks for the tips so far - here are my results!
    By dcarlton in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-02-2011, 06:07 PM
  4. quick question about vacuuming with sand filter.
    By rnjng in forum Pool Equipment & Operations
    Last Post: 07-30-2006, 04:20 PM
  5. Tips for gas heater
    By west1745 in forum Pool Equipment & Operations
    Last Post: 04-24-2006, 09:38 PM
