Thread: How long to clear?
Threaded View
    Default How long to clear?
    First my recent readings
    FC 3
    TC 0
    ALK 50
    CYA 15
    Ph 7.2
    18x 36 IG grecian pool, approx 27k gallons
    Next, opened pool 2 weeks ago, swampy green, and 3 continuous days of 3 big walmart jugs got things to cloudy. Things were coming along quite nicely until I realized the big brown smudge in the shallow end was SAND!
    Found the vertical pipe in the sand filter broken off at the base. Replaced and replaced the sand. Water cleared to a point and I broke out the secret weapon of DE powder this morning. Added about 1/3 cup and pressure went up one pound so things appear to be good.
    How long before water clears? I suspect the cloudiness is dead algae and pollen. Pool does hold shock value overnight. Wife is getting impatient.
  1. How long should it take to clear black algae
    By joecus in forum Dealing with Algae & Slime
    Last Post: 08-08-2011, 02:28 AM
  2. How long to clear dirt?
    By dawndenise in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-19-2006, 05:11 PM
  3. HOw long??
    By cruzmisl in forum DPD-FAS based testing
    Last Post: 07-16-2006, 12:39 PM
  4. Clear solar cover options? Magni Clear?
    By PoBoy in forum Pool Equipment & Operations
    Last Post: 07-10-2006, 12:01 PM
  5. How long does it take for your pool to clear?
    By rtpatter in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-19-2006, 11:37 AM
