Results 1 to 10 of 15
Thread: a couple calcium questions
    Default Re: a couple calcium questions
    Thanks for the reply. Whats the best aeration for quickest ph rise? I normally use sodium bisulfate if I have to reduce ph, is muriatic acid better?
    Quote Originally Posted by gordyjamz View Post
    Aeration is simply that: A fountain, a sprayer, a gang of splashing 12 year old boys. It raises pH.
    To reduce, in this case, use muriatic acid.
    I'm not really interested in the pH--I'm looking to dose milky water with muriatic acid as it can clear it really quickly--I don't think the dry acid is as effective. But your pH needs to go up first before you can try the acid trick. You could use 20 Mule Team Borax--it's faster than aeration.
    Then, use the muriatic acid to lower pH again it should clear the milky water. This, of course, assumes that excess calcium is your problem.
  1. Couple of Chemical questions
    By Goolsbymd in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 02-19-2012, 11:09 PM
  2. need a couple more questions answered????
    By larry b in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-20-2007, 05:51 PM
  3. Want to add SWG....couple questions
    By mneal in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-10-2007, 09:08 AM
  4. A couple of questions about 1st test results
    By BogeyGolfer in forum DPD-FAS based testing
    Last Post: 07-15-2006, 07:24 PM
  5. New Pool Owner with a couple Questions
    By mrbadlands in forum In-Ground Pool Construction and Repair
    Last Post: 05-27-2006, 09:30 AM
