Re: Does local Govt participate in spreading the stabilized chlorine deceit?
CarlD
				But that is negated by proper, regular testing and by adjusting your chlorination method appropriately.
Seriously, the only WRONG way to chlorinate is without testing or compensating when the test results tell you to.
But this is NOT what this clowns of the Health Depts are saying! They are saying : "use trichlor , as the most common chlorination product, which supplies both active chlorine and CYA,  but be careful! When your CYA reaches 80 or more you're in trouble! Drain the pool!"
They should say:  "Use trichlor only when you have a new pool, and once your CYA reaches 50 STOP USING IT!"
This should be the only logical recommendation regarding the use of trichlor products.
In both cases, the ongoing testing of CYA is a given.
			This is my ticket for Heaven (when all's working..) :
22k Gal gunite IGP
38 SF DE filter, 1 HP Hayward Super Pump
Raypak 350k BTU Natural Gas Heater and solar cover
8 gal Liquidator with bleach
Dolphin robotic cleaner
Taylor k-2006 test kit
