Re: Bleach..How Much is TOO much
stma
Battling green water for the past 8-10 days...pumping in about 2 gallon of 5% daily in hopes things will get better...
Pool is vinyl lined AG and the question:
At what PPM of Chlorine will I start to fade the liner ?? I've been keeping it between 10-16PPM
Thanks in advance folks !
I won over the green monster in four days by shocking to 20 ppm, brushing, vacuuming and backwashing. I don't have a vinyl liner and I don't know if 20 is safe for you, but you can check. Seems that your FC level is too low - it shouldn't take so long.
My Taylor kit arrived after I had already "won the war". Before that I guesstimated CYA and pH with strips and store tests. The store read my CYA as 56. Taylor read 60.
Also, make sure your pH is balanced around 7.4 because chlorine won't be as active at a higher pH. I also used polyquat algaecide. If you have a robotic cleaner even better. Needless to say pump should run 24/7 and you should keep backwashing your filter, or the equivalent routine with non-DE filters.
Hope an encouragement from someone who had just "been there, done that" helps.
This is my ticket for Heaven (when all's working..) :
22k Gal gunite IGP
38 SF DE filter, 1 HP Hayward Super Pump
Raypak 350k BTU Natural Gas Heater and solar cover
8 gal Liquidator with bleach
Dolphin robotic cleaner
Taylor k-2006 test kit
